I have a customer with a 914 porsche with a small block in it. I just rebuilt his #9895 spreadbore holley carb. His problem is when he starts it fuel is gushing out of the bowl vents. New needles and seats, checked floats for leaks, they are fine and float in solvent. Checked float level per holley, these are non adjustable but they are set level, I even dropped the primary float a tad. Now he says he has the same problem. He says he has a holley blue pump, I told him to get a regulator and set it at 5 psi. Same thing. He sent me an email and said he's set the pressure at 2psi and says its coming out of the rear bowl vent. Not sure of the accuracy of his gage so Im gonna go and check it out. I might try to start the car without the pump running and then turn it on see if it floods over. Then crank the regulator down some more.
Any thoughts suggestions would be appreciated. Thanks!
