i have a small block 350 4 bolt main
i have 350 heads 458642 with over size valves and been shaved down for more compression
the said the compression is 10:1 with pistons
i have flat top pistons bored 60 over
the cam is a performance 447 lift cam
and a summit hei performance distributor
with flow tech header with after burners
and bum 2300 stall torque converter
Edelbrock 4bbl Carb 750 cfm
Edelbrock performance rpm manifold
stock rockers for now
just wondering how much horse power will the motor have ??
the car is back together and running good i have put 683 mile on the new motor.the car came with a 250 inline 6 and we swaped it with the 350 with not proplems. will try to post pics asp
this simuilates power from the motor. power at the wheels is unknown. this program is just an idea. if the engine isnt tuned by a dyno specialist, it could be off signifantly. and if spark isnt maximized, it will be lower also
0.060 didnt make much of a difference for me to repost a picture
I just want to know how does it drive/sound? It sounds like a peppy budget build. Would be sweet to get a manual valve body and some rear gears
it drive real good.the hole front end was rebuild about 1 month ago so she handle like a new car of the lot. the sound is loud it just have two purple hornies to the headers and run back and out near the front of the rear tires the body will start get dint free and rust free and then a paint job.
the rear end i going to get rebuilt hopefully next year to put in a lower gear and posi trac in it
