All she does is crank but wont turn over. the timing light is not firing neither so I reestablished TDC with a rag and harmonic balancer indicator. lined up the rotor on a terminal and ran my wires in the firing order. there still was no flashing coming from the timing light, the engine just kept cranking without starting. I pulled out the multimeter and traced my 12 V throughout the ignition system and the distributor is getting 12V. So i checked the plugs and the were oily. Will this prevent the engine from firing? I replaced the intake manifold gasket a few weeks ago, and removed the valve covers without changing the gaskets. there was a little oil on the manifold smoking when it was running. I think it came from the valve covers when they were open. The last thybg i did was pull the number 1 plug, connect the plug wire and used the exhaust manifold as a ground, cranked the engine and checked for a small blue spark. there was noneShould I change the gaskets and get new plugs first? Or is there some other tests of spark I can do?
