Hey all, im new to this website ill be on here more now
But i have no clue what happened so i got my carb cleaned and put back on and then i replaced the hazard lights fuse on my 1971 nova and the car has no power in it at all, the horn does work but none of the lights work at all the electric fuel pump doesnt even come on either. The fuel pump will work sometimes but then the car wont start it wont turnover and once i turn the ignition off and try again the fuel pump will not come on anymore
Any solutions to this problem?
Welcome to the Site :waving:
I dunno the answer to the situation you have.
But have you checked your grounds...???
Welcome to the site...
Sounds like a wiring issue to me... first look for any questionable spots in the harness. Otherwise start at the battery then fuse block then everything in between.
Banned
probably shorted something out and burnt the fusible link wire... it's shown at the very top of the 1st schematic, coming off the battery... take a look...
Charge your battery, fusable links, check your ignition switch because a faulty/intermittent moody switch can be a real pain in the arse depending!
