I just got my 67 out of storage and I took it for a drive. I went to stop at a light and the front wheels locked up. I limped the car home and found that the master cylinder rear resevoir was nearly empty. I guess the reason the front brakes locked up so easily was because the rear brakes wern't doing any work so all momentum was pushed to the front of the car.
As a result I've been trying to bleed the rear brakes but air is constantly being pushed through the clear inspection tube I connected to the end of the bleed nipple. Me and a friend must have pumped and cracked the bleeder a good 35 times and still no better results.
We also noticed that if we pump the brakes quickly and immediately remove the master cylinder cover, the rear resevoir fluid looks white because the fluid is entraned with so much air, almost like the fizz from a soda pop. The fluid eventually goes back to a transparent liquid like it should. The front resevoir never gets fizzy and always stays clear.
I know the fresh fluid has made it's way to the rear brakes because I could tell the difference between the old fluid and the new by it's color change.
Does this sound like the master cylinder is shot? It looks original to the car so it could be worn.
Does this sound familiar to any one?
