Guys
I hope you can give me an answer. I have a chance to get a newer style SBC short block, 1994, (350) 4 bolt, with the one piece rear main seal. My main question is could I use my heads off of my old style block, two piece rear main seal block. The heads are Edelbrock RPM part # 60899. I already have the RPM air gap manifold with the heads. Also can I use the water Edlebrock aluinum water pump from my old block as well. It needs a rebuild, but has the oil pan, timing chain cover with it and has the stock roller cam with lifters. Are there any disadvantages to this set up. Or am I just spinning my wheels. Oh Ya, only $150 for the short block.
The Gen 1 heads fit on all SBC blocks except the modern LS and reverse flow LT1
Hey Paul
Just noticed the "back home" location.
Havent been on much lately so sorry if I missed your return, but it's good to see you home and safe. I have a close friend there tl the end of the year...he's in the thick of it, Ranger, Airborne, SF type....built the two rifles he's now using over there for sniping work.
Been back since April. I presume your friend in in Afghanistan.
