Hey guys as some of you know I just picked up my 1971 nova, I have a question about it. It has a 4 speed muncie with 396 full roller motor and apparently 3.73 gears 12 bolt rear end. When I drive down the country roads at 80kmh the car revs at 5000rpm?? Is that normal? Thanks in advance for the help!
Are you sure you are in 4th gear?
If you work backwards:
80 km/hr equals 50 mph, or one mile every 1.2 minutes. A 26" tire turns about 800 revs/mile. 800 revs in 1.2 minutes is 667 rpm. Multiply by the rear gear ratio will give the driveshaft rpm - 2486 rpm - round off to 2500 rpm
Divide the engine rpm by the driveshaft rpm 5000/2500 = 2
Somewhere there is a 2:1 reduction in your gearbox.
Muncie ratios:
M20 Wide-Ratio 1963-’65
First Gear 2.56:1
Second Gear 1.91:1
Third Gear 1.48:1
Fourth Gear 1:01
Reverse Gear 3.16:1
The only thing close is second gear, which occupies the same bottom of the H as 4th.
Is your tach set up for an 8-cylinder? A 4 cylinder setting will double the displayed rpm.
Discussion Starter · #5 ·
I never thought about the tach setup I just installed it, didn't know there was a 4cyl and 8 cyl setup. I'll take a look at it today, but it sounds like its definitely revving higher then 2500rpm if the revs drop in half for 8 cyl. Thanks guys, I'll get back to you as soon as I check it out.
Muncie ratios:
First Gear 2.56:1
Second Gear 1.91:1
Third Gear 1.48:1
Fourth Gear 1:01
Reverse Gear 3.16:1
Discussion Starter · #6 ·
Thanks Mike! I changed the tach to 8 cyl and now its revving at 2600rpm and for some reason stopped sounding like its revving too high. Must of been a mental mind thing.
Amazing how your mind will trick you. Good to see you have it going.
