Well i just changed my outer tie rod ends. Before I removed them, I measured from the edge of the adjuster sleeve to the center of the stud on the end of the tie rod. I also counted the turns it took to remove the piece. I replaced each side one at a time and counted the turns and checked the measurements to get it back to close to where it was before. Well, afterwards I pulled it out of the garage and started to test ride it, and noticed something definitly wasnt right. Looking from the front the wheels appear to toe outwards. I cant figure out why now? Like I said, I measured prior to, and after insatallation.
Now what? One thing that did catch my eye was that one of the old tie rods was slightly bent. I dont know why, but the new ones are both straight. Could someone have aligned it with a bent rod, and now with the new one being straight, maybe thats causing my problem?? Whats the best way to get the wheels working parallell to each other, to get it close before a proper alignment? Thanks
