That would be a shorter shifter and could work but you’ll need to buy the Hurst shift lever and the base plate shift tower assembly. The S10 doesn’t have the ability to accept that shifter. Alternatively, you could get a stock F body shifter from 82-2002 T5 equipped vehicles. They are way shorter and straighter then the S10 setup you have now..
Hurst sells many different styles of shifter handles for the T-5. The first thing you need to know is if your transmission is installed straight up or tilted 15 degrees like the Camaro. A Camaro shifter on an straight up installation will put the shifter handle closer to the driver and may interfere with the 1st and 2nd position. Sit in the car, hold your hand where you want to have the knob and measure to the shifter. Then go look at all the handles Hurst has and find one with the dimensions and offset that suit you.
