1 - 14 of 14 Posts
Built a new motor for 2013. Built for auto x/road racing not drag racing.
Dart Block
4.125 bore x 3.48 stroke
Eagle lightweight crank
Eagle 6.00 Rods
JE pistons. 11.1 CR
AFR 210 Heads Fully CNC ports
Custom bullet cam. 24*/25* and lift is right at 600/600
Single plane EFI intake port matched to heads
Holley 1000 CFM TB
Holley crank trigger
Holley DIS coil set up
1 3/4-1 7/8 stepped headers.
This is what started the new motor build.
Not enough ring gap lifted part of the piston?
Motor specs sound like it should do pretty good in the quarter depending on the cam.
Nice.:yes::yes:
That new engine combination should be STRONG :yes:
Nice.:yes::yes:
On the old motor, it was a 355 that came in the car when i got it and knew nothing about what was done, I was spinning it to 7000 plus RPM almost everyweek.
So in other words you were having lots and lots of fun.:D
Hope the new one works great for you and I like the parts list.:yes:
Does anyone want to take a guess at dyno number?
Discussion Starter #9
Under the hood is done. Motor runs and I drove it down the street. I need some nice weather. It revs super fast.
[/IMG]
Very sanitary.... your detail is top shelf, well done :yes:
Beautiful engine bay, and nice engine build too.
Can't go wrong with AFR's.
I'm gonna guess around 575HP.
1 - 14 of 14 Posts
