I'm thinking of buying a new carb for my 67 194 automatic. It has the Rochester BV now. It's not the original carb, it came with a rebuild and is the part number is for a manual trans while mine is an auto. It runs good going down the road but I've never been able to get the idle perfect. It randomly stumbles sometimes when sitting at a light and I have to run the idle speed higher than original spec or it stalls randomly. I would say it is 90% good and it's certainly driveable. There are stains down the side like it leaks some, so the body is probably warped. I just did a full tune up, idle vacuum is 19 and I tightened all the manifold bolts and sprayed around the manifold while it was running to check for leaks.
I drive the car every day, all I care about is reliabliity. I might drive from Florida to Maine next month and don't want any trouble on the road. I don't need more power. I want to keep the original air cleaner and intake manifold and everything stock appearing. No 2 or 4 barrels. I want new, not rebuilt. I don't want to deal with crappy rebuilds on worn out cores. I would prefer to keep the automatic choke. If I could find a new NOS, not rebuilt BV I would do that, but the only ones available new seem to be for pickups with different linkage and manual choke.
On ebay I saw a new NOS Holley 1920 economaster and a new NOS Carter YF. Both of those were sold back in the day as direct bolt on replacements for the problematic BV. I also looked at the Daytona universal 1 barrel replacement carb.
Does anyone have a recomendation or experience with any of these?
