My 350 motor was a purchase from a member here and he said it is a rebuild that he purchased.
Anyway....Considering the engine's numbers (14016379 a 4 Bolt Main, I checked it is) I have to believe the nasty looking tiny 6" harmonic balancer was not original to it and should be replaced .
What size balancer should I choose? 6", 7" or 8"? And how do I make sure it will line up with a aftermarket timing tab correctly?
Most 350 engine timing covers are setup for an 8" balancer. Timing marker would be off if you put something smaller on it, unless you changed the timing tab/cover to match.
