After installing a new 383 Stroker, the pointer on top of the harmonic balancer, won't allow Saginaw style Power steering pump to fit properly. The new pointer is a block of aluminum billet, with a steel needle pointer. It prevent the bracket that hold the pump, from fully descending. This make the pump lay too far to the left of vertical, and not move enough over to accept the belt. I can't mess with the timing pointer, without making timing possible. Holding up my project. Need suggestions/solutions!
