You can check the block casting number to verify what cid engine it is, also the 307 used a small two barrel carb and the 350 carb was a larger 2 barrel. Most of the engines back then liked 10-12degrees initial timing with the vacume advance disconnected. Idle speed should be about 700 in nuetral. Set your dwell before the timing.
