Hey fellas I need some help, fast.
Im RE-building a 468 Gen IV BBC for my 70 Nova. Heres what is going into to:
70 454 block, bored .030 over
Reground factory crank
World Merlin II Rec. Port (119cc) cast heads.
Comp Cam Hyraulic roller (11-430-8) (280/280)(224/224) .566/.566 110°
I was going to keep the flat tops (with two valve reliefs in it) but after finding problems with the pistons Ive decided to replace them too.
I had a closed chamber 101cc head on it before, and now going to a semi/open open chamber Merlin Head Im thinking Im going to loose a lot of CR. What is the best choice (and best on my wallet) for this build. Trying to stay at 10:1 or lower.
Do I have to run a flat top with a valve relief? Can I run a mild dome piston w/o a relief? Thank you in advance!!
Rob
Rob
