CAn anyone email me a picture from the 'side' of a 275/40/17 tire mounted on a 17x9 rim? I want to see how the tire hangs over the rim. I need to know about how far it hangs over and how the tread surface lines up with the side of the rim. I have a set of 17x9's and the lip of the rim is pretty close to the outside of the fender flare... that is why I want to see a picture of that tire on that rim.
Thanks,
This is a BFG KDW 275/40-17 mounted on a 9.5 rim. With a 9 it would just "arch" a little more I believe.9" rim is low side of suggested with for that tire (9-11) .However, it will vary by manufacturer. I recently replaced this tire with the same 275/40-17 in an Eagle F1 and they are noticeably not as wide, so that could free up some more room for you. I will try to get a picture of the rim with new tire soon
[/URL][/IMG]
Discussion Starter · #5 ·
That picture is exactly what I am looking for. Thanks for it. If you had to guess, would you say that the widest part of the tire buldges about 1/2" beyond the rim lip and the tread might be about even witht he rim lip? Would you mind measuring the actual tread width for me?
Thanks again!
with the new tires I would say maybe 1/4". Seems to make sense since a 9.5" rim is 10.5" from outside edge to edge, and at a section width of 10.9 puts it close to 1/4". The BFG KDW states a 9-11" rim for this tire. The Eagle F1 states 8.5-11", so that seems to back up it looking visibly narrower in tread width. They both state section width as 10.9" on a 9.5" rim though. The tread width appears wider on the BFG, but isn't stated on the spec chart for the BFG. It's 9.7 on the Eagle. A chart states that putting on a 9" rim would subtract .20 from section width, so you would pick up a little more room with the smaller rim also. Hope this helps
[/URL][/IMG]
