1 - 10 of 10 Posts
Does anyone know if there is a aftermarket rad and electric fan combo that can be bought to keep these things cool? I've got a 3 core rad now with a single electric fan that's not good enough. (can't get through Mcdonalds without climbing 20 degrees) The rads not original to the car and there's no shroud on the fan , which I'm sure would help. The car is a 66 acadian with a 425ish hp 350 in it. Thanks
This is not much help, but I had to inject my personal experience.
My 68 Chevy II ran great and the temp red light never came on.
I put in a set of aftermarket gauges and now the car shows 220 with the AC on. I solved the problem with a bit of tape over the temp gauge; now runs great again.
On a more serious side, the shroud should help considerably.
normally speaking low speed overheating issues like this are caused by too little air flow through the rad...a shroud would help greatly with this. Also a lot of people are having good luck using the ford Tauris electric fans...there are quite a few threads on here about that fan....good luck:)
I've never found an electric fan that can come close to the Vintage Air Monster fan that I use--but you need a BIG alternator to use it; it draws a ton of amps. It's 18" and has an adjustable bracket that will fit almost anywhere, and they have a shroud made to fit it perfectly. It's based on a Lincoln Mk.8 piece, maybe a junkyard would have one cheap.
Do a search in the forums for Taurus fan. There are plenty of threads about installing one from a V6 Taurus. They flow over 3000 CFM and are cheap from a junk yard. I picked one up for $20.00 and it completely solved my issue.
Chuck
I didn't even know VA made fans. I thought they just made AC/Heater kits. Awesome. :)
Matt
Greetings,
Are you using a stock iron water pump? A good high-flowing water pump will cool things down as well and would be less money than a new fan/radiator setup. I'm running the Flex-A-lite dual 10" fan setup, Summit aluminum radiator, and Stewart Stage II water pump. No cooling issues at all.
Jason
A proper fitting shroud and a good mating fan installed correctly should cool most of the small block engines in Novas. There have been a number of heat related cooling problems that have been discussed before with various solutions. You can do a search for them with the search option in the task bar near the top right side of the page. I'm not a big fan of most electric fans unless they are the Taurus/Lincoln ones. I'm not familiar with the VA one but it may be a good one. Personally I've tried some of the other company fans and they never cooled as well as a fan/shroud combo that is properly sized and installed. My favorite fan is the 70's Caddy 500 c.i. mechanical flex fan from GM. It's a tight fit in the reproduction Nova shrouds.
Where are you in Ontario?
I fixed my 66,s over heating problems permantly without a fan shroud [I don,t like em].Griffin aluminum rad and a 2600 cfm electric fan.Never gets over 195!
1 - 10 of 10 Posts
