does anyone know if I am supposed to run the cable above or below the four link? I think with the leaf springs it goes under. So I put it under and it looks kinda like maybe it should go above? or does it even matter?
i"m sure one has done this before, any help is much appreciated.
418584
I think your answer will be after you do two things. Leave it there and while watching things see how far the axle drops which should be limited to the shock length and then raise the rear axle all the way up to where the top of the axle tube hits the rubber frame stops. If no pressure is put on the emergency brake cables, then it's good where it's at but if it does hit then the cables may have to be relocated.
Which 4-link did you use? I ask because I used the Church Boys 4 link and have not put mine back on yet. I also had to remove the bracket (like step 2) so I have to re-locate and reinstall that as well, I was hoping someone had pics of it back together as well.
