i have a cpp factory style front disc kit for my 66 nova.the instructions is one sheet of paper with one picture of the caliper bracket mounting.it shows the caliper on the driver side to the right with the bleed screw at the top.my problem is the brakehose will not line up in opening for the banjo fitting.i can grind and cut the caliper to work the hose is hitting steering arm and spindle.
