I JUST GOT A 194 HEAD FOR MY 250. I KNOW THE COMPRESSION RATIO WILL BE HIGHER, BUT WHAT CAM SHOULD I USE. I ALSO PLAN ON THROWING A TURBO ON THIS THING. SHOULD I GO WITH A CLOSER TO STOCK OR A PERFORMANCE ONE? I FOUND THIS ONE ....High Energy 800-4800RPM; advertise duration 252 int./exh.; valve lift .474 int./exh.; lobe angle 110 deg. WILL THAT WORK?? ALSO WHAT VALVES SHOULD I GO WITH? I WANT A LITTLE BIT BIGGER FOR THE NEW HEAD.
