what carb and tires are you running
Yes it is and now you are talking.:yes:foot baking bring it up to 1500rpms is a 3200-3800 stahl streetable
Great, can't wait to see your new faster times. I am running a 4100 (9.5") converter in mine.:yes::yes::yes:well i purchased a 3800 stahl converter hope to get it in soon and see how it does
Good advice, I replaced my u joints with the solid ones. I also use Type F in this 72 I have and in my last 71 as well. :yes:Make sure you're u joints and yokes are in good shape. Also if you don't have a drive line hoop front and rear installed it sure wouldn't hurt. You might also if you haven't already done so throw fird type f trans fluid in it to help firm up you're shifts. RICK
Heres another part you might want to install if you haven't already done so. If you go this route you will also need a filter extenson and filter. RICKhey guys need your help i have 66 nova 383 turbo 350 373 gear on 26 inch tires went to the drag strip ran 12.24 at 115 mph reallt seems lazy out of hole 1.9 60ft time has 2600 stall i think how can i improve on mt et think at 115 mph thru the trap i should be around 12.00 or can i be wrong thanks for the info iam new to drag racing
