My left door is too tight. The latch rubs when I close it. How do I go about adjusting it? Is this a matter of shimming the front end out on the left side?
I think this is a result of putting the car up on jack stands while replacing floor and trunk pans. At various times I had the front setting on jack stands under the frame rails as the shop manual shows where you should put 4 post lift arms. When I would do this the front end would droop slightly (engine and trans still in). This would cause the rear door gap to get wider such that the door would not even latch. Usually I jacked the front end up by the very front ends of he frame rails so that the doors would shut. Could this be why that door doesn't fit right now? Here are pics of the gaps. The front of the left door and front and back gaps on the right door all seem good. The rear gap on the left door is too small.
