Need a radiator
1905 Views 8 Replies 7 Participants Last post by  Steve-66
I need a radiator for my 70 nova with a 396.Right now there is a 4 core small block radiator in there now.I would like to find a correct size radiator,but all I see listed st the parts stores is for 69 camaros.Will these work? Most listings describe it as having two 1 inch rows and about 18 inches tall by 23 wide apr.I dont see any listings for novas with big blocks.
1 - 9 of 9 Posts
3-row radiator is for L6 and SBC.
4-row was for BBC, so it sounds like you already have a big block radiator.
I thought BB radiator supports were cut wider allowing a wider radiator to be effectively used?
I run a Ron Davis radiator...expensive ($550), but fits like stock and huge aluminum job. That and a 16 inch Spal electric fan on Summit brackets-reliable cooling. The fan connects to my Holley EFI for control.
Trythis I bought the 2 row aluminum radiator from them for my 350 and it never sees temps over 190 195 TOPS in 110* weather.
Summit Direct Fit Radiator 31x18 Not exactly cuz i wanted a 31" rad to fit the double fans. However I use the stock hoses and it fills the support end to end
that looks good wouldent have a part number on the radiator? How hot does it run with that set up?
http://www.summitracing.com/parts/SUM-380482
This is 31x19 direct fit summit rad. It will fit in the rad support. Sometimes I need to turn off the fans. Depending on outside temp anywhere from 170-190
1 - 9 of 9 Posts
