I have a chance to by a 12 Bolt that at has been narrowed. What would you have to do to install correct axle tubes and would a 10 bolt tubes work.
So, you want to return it to stock length? If so, it depends on how they installed the existing tubes, as in, did they weld them all the way around or what? Might be more trouble than its worth.
T,
What is the width now? If you did retube it you could put Ford 9" big bearing ends on it and eliminate the C-clips.
How much $$?
Intended use?
What is the current width?
I shortened a 12 bolt from a 64 Impala to the factory length and used Chevy II 12 bolt Axles from Moser, works great.
