here is a great set of heads that come with a better total package!
GM Performance 350 Crate Engine 290 HP HO 12499529
Can be purchased for less than 2 grand !
Our lowest priced Performance crate engine.
Quite simply, the 290 HP 350-cubic-inch is the best small-block crate engine value offered by GMPP! With 290 horsepower and 326 lb.-ft. of torque, it makes a great replacement engine for countless GM vehicles, while its all-new construction provides peace of mind over salvage and rebuilt engines. The 290 HP is packed with good stuff, too, starting with the four-bolt-main block, aluminum pistons, and a hydraulic camshaft. The durable iron cylinder heads process healthy amounts of air to deliver strong torque across the rpm range and great mid-range horsepower. Delivered as a long block assembly, you add items like an intake manifold, carburetor, ignition system, starter, balancer and water pump—all available from GMPP. Build it up to suit your needs, as the economical 290 HP will leave plenty of change on the table! Our lowest priced crate engine.
This HP 290/350 is the best value crate engine from GM Performance Parts, with 290 horsepower @ 5100 RPM, and 326 lb-ft. of torque @ 3750 RPM on 87 octane fuel.
The HP 290 horsepower will provide great durability because of its 4-bolt mains, PM steel rods, strong cast aluminum pistons.
The camshaft has .450" intake and .460" exhaust lift with hydraulic flat tappets.
The cast iron cylinder heads have 1.94" intake and 1.50" exhaust valves wit 76 cc combustion chamber. These heads have the conventional 90 degree with 12 bolt intake manifold attaching design used from 1955 thru late 1980
IMO!
