41 - 60 of 145 Posts
I know what you mean. The OEM look is always best IMHO. Even the intake doesnt seem out of place... Looks tight.
You could paint the intake and most people wouldn't even notice it's aftermarket.
Discussion Starter #43
pretty sure the oem high hp 427 came with alum intakes , beside i never liked orange intakes and black would have made it look like a late 454 truck engine
but ya it would have looked more oem but even i only carry a theme so far
Discussion Starter #44 (Edited)
heater hose
found some time today to finish up the heater hoses this how it looks i used the clamps for a gen 3 along with the bb heater core /cover
Discussion Starter #46
Really nice work you are doing! :yes:
well i do not show you the hack stuff
thanks just still trying to make look like the 427 was born there ,plus fix all the hacked up stuff from over the years all that left to do under the hood is repair and run engine wire harness and put in the dist and bolt down the carb
Good to see you still at it, keep pressing on, the engine looks like it belongs in there.
Well done!
Discussion Starter #49
Well done!
thanks i only seem to ave time to work on it for few weeks in dec jan if i do not get ready to at least roll out by then end jan it will end in the cellar for another year
Discussion Starter #50 (Edited)
oil psi sending unit
well got a little done ,got the oil psi sending unit , seemed like i simple thing to do , frist attempt above oil filter no go z bar /linkage clearance problems
then it to drivers side oil passage ,pull last plug near front it 1/4 thread not 1/8 thread like the lighter duty block
so off to the internet for a little research i wanted a 1/4 thread because i did not any adaptors less chance of breakage
1980 454 with gauges c20
Discussion Starter #51
more de hacking
the problem with owning a car a long time (1984) if sometimes you find the things you did on budget late at night with friends, and still had drive the car home may not been the best idea
well under the car looking up i notice rear brake lines hanging in the air not attached to the body or axle
well that bronco 9 inch that i put in using Lincoln mark v disc brakes needs some love
the brakes never really worked , mostly because of problem i have already fixed up front
brake lines on the mark v brakes point the wrong direction and i was never able to rig up the emergency
so after Christmas the rear brake dehacking begins
1 remove the 1/2 wheel studs and put back in 7/16 so if i get new wheels they fit right
2 remove mark 5 stuff
3 change the brackets so i can use gm metric calipers (80s regal ect]
anybody that used the gm metric what did you use for emergency brake cables and how did it work out ?
The park brake cables were not an issue to install, the metric caliper itself is very prone to problems. After a year on my 77 they were removed and replaced with a set up used on the 98 - 02 F body, or what most refer to as LS brakes.
Discussion Starter #53
oops wish i had know that , well i got them allready , they got to be better then the mark 5 ones i got now and they sure are lighter
do the 98 - 02 F body units fit in your same brackets
thanks for you help i found info on the cables later on your build page
The ls1 brakes use their own bracket because it uses an in hat style parking brake that looks similar to a drum brake. They also require 17 inch wheels, but are far superior to the "metric" calipers. If 17 inch wheels aren't in the budget, I have found people who are using the rear disc setup from a 98-03? 4wd blazer. They look very close to the same thing as the ls1 brakes, but can fit inside a 15 inch wheel. Don't know how either ls1 or blazer setup will interface with the flange on that 9 inch though.... Might require some drilling.
The cables I used were from the donor car and both ran down the drivers side. Cables can be purchased or made to tie into the existing park brake intermediate cable. I moved my drivers side shock to make the install of the brakes easier.
As said the Blazer/S10 rear discs will work with 15" wheels, here is a "how to" link with parts needed.
The link shows the parts to install with shocks in the stock location.
http://www.nastyz28.com/forum/showthread.php?t=109454&highlight=s10+rear+disc
Discussion Starter #56 (Edited)
this is what i am going to try
Bracket Kit only for PEM Bolt On Rear Disc Brake Kit for 9" Ford with GM Metric Brake Calipers
This kit includes bolt-on caliper brackets with hardware and bolts for one 9" Ford Rear End.
Bracket Kit fits both the 9" Ford Torino 3/8" and Old Style Large Ford 1/2" Housing Ends with a 3.15" OD Bearing shown in picture above.
This bracket kits ONLY fits the housing ends with 3.15" OD Bearing!
The rotor size would be 11-1/4" OD and using the '78-'88 GM Metric brake calipers (rotors and brake caliper kit NOT Included).
Brake offset is changed with included spacers.
this was 80 dollars
the metric e-brake caliper were 50 each
as for rotors i am hopefully reusing tme mark v disc that are allready on the car
as for cables and hoses i was going to replace them any how and the gm metric gm stuff is much cheaper and alot easier to find
should have most everything by sat if so i take some pics
The down side of that type of bracket is it does not support the caliper over the center line of the rotor. There are rotational forces apples to the caliper when braking and these types of brackets place the force on the slide pins which are not designed for that types of use.
I do not know what the Ford bracket looks like but here are photos of some GM rear disc caliper brackets.
89 Camaro
This one is from an 82 Eldorado and was used on my 77.
Here is the install using after market brackets
Things to watch for when using the after market brackets are rear brake chattering, uneven pad wear, caliper binding causing poor braking and calipers not returning fully due to bent slide pins.
Things I experienced using the GM rear metric calipers on GM brackets were
Prone to leaking around park brake shaft in caliper
Difficult to bleed air out during initial install
Pads not staying adjusted even with regular use of park brake
Park brake failing to hold car
Discussion Starter #58
89 Camaro
thanks for the help , i must say i am more then a little unhappy about this brake thing , i already purchased the parts now i own them
the stupid thing is i did research first in found no complaints , but just looking at you pics tells me that this set up is only i minor upgrade from what i had before , granted this car will only get about 1000 miles a year
Discussion Starter #59
i think i like eldo bracket better then the one i got
and it looks to be stamped steel so it could be weld / modified if needed
Sorry was not trying to make you feel bad. I did want you aware of what I have experienced. It should help knowing what things to watch for. Make sure your brake warning light in the dash is working, it alerted me when the caliper started leaking long before it was a safety issue. It will also come on if the adjustment gets way off.
