I’m leaning towards building a console. I think I can make the hand brake work too. Going to move it forward and lean it over towards the passenger. I can get it lower when I install it since I’ll have to fabricate a bracket.I would find a console first, then take the matching handbrake lever at that point. I still need to get a handbrake for my Neon console, but I don't have the e-brake hooked up currently in the car.
I thought the Nova “kit” from VA ran the lines through the oem blower hole, down through the kick panel vent? That approach for the lines seems to work well for the TXV and heater connection points I assume? I wasn’t really considering the hidden lines at this point. I’ve already got plenty on challenges to overcome on this task. Although, that would certainly clean up the engine bay. I’ve got work to do to my fenders so I could probably spot weld some hangers on the inside. Where would the lines enter the cabin? Through the kidney sidewall into the cowl vent plenum? Interesting. I’ll have to research that more. Did you go with the sure fit kit?Dash vents are way better looking. More of a custom look and not something added on. That is something I would like to do one of these days. For now mine are the standard under dash vintage module.
While your doing your evaporator "evaluation" make sure to include the routing of heater hoses and A/C lines to your unit. If coming through the firewall into cab, not too big a deal but if your thinking of under the fenders, whole other ballgame.
Appreciate the suggestions. I’ve put very little thought into the AC/dash installation/appearance details until now. The evaporator box position makes the glove box useless. I’m favoring passenger leg room/maximum height over glove box space. I’m thinking I’ll put the fuse block behind the door right now. Other things I’d like to have in this car include power windows, power locks, power trunk release, security and a decent stereo. I think the time to deal with my seats is fast approaching too. Looks like I’ll need to make a custom console for some electronics and cup holders to live in. Switches, buttons, park brake and even head unit possibly.I did use the sure fit kit originally. When I changed front clip to CBR I redid the A/C connection account I wanted everything I could out of the engine bay. My kit for the 67 had the heater hoses going through the oem location on firewall and A/C lines also (mine was not an A/C car).
I couldn't find any pictures I took of how I did it but it's almost like these that I remember Nova66mussl posted (hope he doesn't mind me using them). I did mount the dryer on firewall just to the left of where the lines go through on passenger side under the fenders. Again mine is 67 and this on a 66.
Also I changed the A/C lines and connections to EZ-Clip types as they are smaller OD and you can make them up as you go. Not trying to change the direction of your build, it's awesome as is, just something to think about in the process.
That evaporator looks different then the one I have in my nova. I have my lines running through the kick panel and out to were the fender will be. I plan to run it up in the fender and come out in front of the inner fender. But my ac outlets don’t come out from the top. I’m just curious what has changed.I propped the Vintage Air evap into position which spiraled into multiple new considerations. Dash vents, dash pad and gauge panel. The evaporator will fit there ok. I don’t think I can make the duct connections to an under dash vent kit work though. Doesn’t look like there is enough room plus I think I would prefer dash vents. That’s another project since my car didn’t have factory AC. That means a new dash pad and instrument cluster, which is needed anyways since I have Autometer gauges. That introduces a new problem. There are plenty of replacement dash bezel options out there for 5” gauges, but I have 3-3/8” gauges. I can’t find any adapters but I’m hopeful I can solve that problem. As far as the dash vents, I’ve seen a thread on this site where someone did it. I’ll have to research that out. Seems like there was some complication with converting, but doable.
These are pictures I pulled off the internet of under dash and oem vent locations. I definitely prefer the oem look, and leg room.
Also I’m not sure how that one mounts but mine was calling for a bolt to go through one of the only heater core bolt holes and I didn’t want that to show since I smoothed the fire. So I made a little bracket and bolted it through the cowl and just reverse the mount.I propped the Vintage Air evap into position which spiraled into multiple new considerations. Dash vents, dash pad and gauge panel. The evaporator will fit there ok. I don’t think I can make the duct connections to an under dash vent kit work though. Doesn’t look like there is enough room plus I think I would prefer dash vents. That’s another project since my car didn’t have factory AC. That means a new dash pad and instrument cluster, which is needed anyways since I have Autometer gauges. That introduces a new problem. There are plenty of replacement dash bezel options out there for 5” gauges, but I have 3-3/8” gauges. I can’t find any adapters but I’m hopeful I can solve that problem. As far as the dash vents, I’ve seen a thread on this site where someone did it. I’ll have to research that out. Seems like there was some complication with converting, but doable.
ya, mine are on the side toward the driver side as well. I wish I would welded mine on before I painted it but I Didn’t have it yet. So building that little bracket was the next best thing.Air outlets on the evaporator I have are not on the top either. They are on the left side toward driver's side of unit. What I did for the top mounting location was to weld in a stud on the firewall (cab side) when I did the firewall clean up. Not visible from engine bay.
The unit I have is the Gen 2 Compaq which is part of the builder series. Because I have the roll cage tube extending up to the firewall, I didn't think the sure-fit solution would work. If memory serves, the evaporator for the sure-fit kit was larger in size. That evap box is just a mock-up unit.That evaporator looks different then the one I have in my nova. I have my lines running through the kick panel and out to were the fender will be. I plan to run it up in the fender and come out in front of the inner fender. But my ac outlets don’t come out from the top. I’m just curious what has changed.
