I agree, that is odd. There are re-pops of those parts. I saw them in the Classic Industries catalog.Weird how it got mangled it's not easy to bend.
That’s one of the major considerations. I know these fit. They are in generally good shape less the lowers. There does appear to be a small area of damage, at the door seam on one of them which has me concerned. It’s weird though. It’s a slightly raised “dent”. I assume from door contact at some point in its life. Not damaged otherwise from what I can tell. I looked them over pretty well today. I’m contemplating breaking out the sand blaster to clean up the inner surfaces, support brackets and rusted area. If I do, it’ll be a bigger project because I’ll batch the inner fender wells too. I’m not sure how I’ll handle protective coating it all after that. It’s winter and the epoxy primer will be a pita. I may break out the phosphate acid and save the primer application till spring, or a warm day anyways. Feels like I’m getting myself all tripped up on this project lately. Must…keep….working…on…it.If it's just the lower corner, I'd save them. As you (and all of us have found), even the best and/or most expensive aftermarket panels aren't as good as OEM for these cars.
I certainly won’t make the claim this project has been well planned.I think this thread illustrates one thing very well.
No matter how well you plan it out there will always be reworks or “that one little thing” you have to do.
Yes they were. An odd way for the factory to attach them I think. Not sure how I will attach the new ones. I know I wont be stapling them. Maybe some nutserts.The staples held the rubber control arm skirts to the metal inner fenders.
They sell replacement staples for use with reproduction rubber shields, You assemble and bend by hand, back through the original staple holes in the inner fender metal.Yes they were. An odd way for the factory to attach them I think. Not sure how I will attach the new ones. I know I wont be stapling them. Maybe some nutserts.
I think something removable makes more sense. I’m addicted to those damn nutserts now too. Maybe some simple modern plastic clips would be more appropriate.They sell replacement staples for use with reproduction rubber shields, You assemble and bend by hand, back through the original staple holes in the inner fender metal.
Maybe you already know this, and just want something more professional looking than staples....?
That’s wild. Mine didn’t have those brackets. They may have come off when I pulled it apart, a long time ago.The nutserts may be a good idea for your car and application. I had to re-make the rubber splash shield on the drivers side under the fuse panel -- They don't even show that part in the factory assembly manual. And no one makes a replacement that I know of. Putting the staples back in is a pain to get right especially on the wheelwell inner fenders. The bottom photo is the un-restored original.
