681 - 700 of 711 Posts
1974 Nova SS
Discussion Starter · #682 ·
What's going on at the driver side of your track bar? I can't figure out how it's mounted from the picture. It's nice and flat though, doesn't get much better than that.
It's an offset clamp assembly from Speedway. It clamps onto the square downtube and provides an offset 3/4" bolt for the panhard joint. When I was making the panhard bar, it made sense to offset it longer rather than shorter. I am slightly concerned with the axle bracket length. The axle bracket started life as a Speedway bolt on job. I had to section and extend it by 4" to get the mounting point out to something like 8".
1974 Nova SS
Discussion Starter · #686 ·
Got back to work on the tunnel sheet metal. Had to cut more tunnel out to get the driveshaft in, then more to allow clearance for suspension compression. I am happy the driveshaft fits correctly. Also happy the 4-link crossmember cut out is correct. Full droop is good with driveshaft clearance. I discovered another “to do”. Have to figure out a bump stop solution for the rear axle. That will be somewhat tricky given all the apparatus already on the axle and a general lack of room. This task sure snowballed. I originally had a single piece of sheet metal to cover the tunnel but had to section it to get the height and fit correct. Still have to figure out the driveshaft safety loop too. Lots of work to do.
Motor vehicle Hood Automotive tire Combat vehicle Automotive design
Hood Automotive tire Motor vehicle Vehicle Automotive design
Tire Wheel Aircraft Automotive tire Tread
Tire Wheel Land vehicle Vehicle Automotive tire
Hood Automotive tire Motor vehicle Bumper Automotive exterior
Motor vehicle Hood Automotive tire Automotive design Bumper
1974 Nova SS
Discussion Starter · #690 ·
Shifter hump next. This is an interesting challenge. I would like to make the entire hump removable. As of this moment, the plan is to make a lower flange (flat) out of 14ga. (Template shown). Then an upper flange out of 19ga. For the fore and aft ends, I’ll have to make sheet metal flanges and stretch them to the curve of the tunnel. For the sides, one piece filler sheet meta with a flange broke on the bottom. Then filler pieces front and back.
One idea I’ve been considering…making the top plate smaller (than the bottom opening) and angling the sides. This would really only affect the front because the back is going to need to be pretty much vertical due to the positioning of the upper shifter boot. I admit, I do think it will be much easier to make a symmetrical box without angles, from a fabrication perspective.
one think that is bothering me, if I do make a “box”, that will leave a hard corner right next to leg/hip. I don’t know if it’s really an issue because the car will have 4 point harnesses and hopefully a console over the shifter hump. But I still don’t like it. Rounded corners would be better but I haven’t figured out a reasonable way to make that happen yet. There is solid chance the console won’t be there for a while though. I don’t know, have to sleep on it I guess.
one thing is for sure, this tunnel/shifter hump fab job is a lot of work!
Hood Automotive tire Bumper Automotive exterior Gas
1974 Nova SS
Discussion Starter · #696 · (Edited)
Finished welding the hump-box to the flange. I was originally going to flange and spot weld the box to the flange…then I cut a corner and decided to weld the box to the flange, because it was easier. It would have been much cleaner to use the flanges I think. As far as attaching it to the tunnel, I was going to use riv-nuts and Allen head cap screws but I may just try some sheet metal screws and see how that works.
my CPP hydro boost showed up. Looks good.
Automotive tire Hood Light Motor vehicle Automotive design
Motor vehicle Hood Automotive tire Automotive exterior Trunk
Motor vehicle Wheel Hood Vehicle Automotive design
