Driver side rear frame section. Part 1
I finally got to start cutting on the car to get these rear frame rails moved inward.
Earlier in the week I made some adjustable supports for the rear of the car. I used 1" steel pipe and 3/4" threaded rod with some threaded floor flanges. I tack welded the top to the frame and tapcon screwed the flanges to my garage floor. Does the trick!
Once i had back half of the car supported, I started cutting out metal. I cut out the trunk pan to make access to the frame rail easier. I need to replace the trunk pan anyways so...
Sectioned the inner wheel well to get access to the frame rail on the outer side and cut some relief slots in the remaining trunk pan material to allow the flaps to be bent up and out of the way. Drilled the spot welds and used the air chisel to start separating the welds.
Almost ready for the big "hope I don't @#$% this up" cuts on the frame rail...
