1 - 20 of 138 Posts
Discussion Starter · #6 ·
Been watching your build on Tech.....gonna be a monster.....umm, just one question, how you gonna connect your steering, will it miss the pipes?
Nice build....
T,
yes the steering box is way down behind the control arm. i am not sure if your car is the same as the 67-74 with the rear steer? there is tons of room.
That going to look real nice! Mine works good but is ugly as hell! What are you using for a transmission and rear end?
Discussion Starter · #13 ·
i plan to use a 4l80e right now it has a 60 in it but i hope its just for mock up and i don't need to destroy it! the rear of the car is all done the car has ladder bars and a stock 8.5 ten bolt with moser axles Eaton posi and richmond gears. 3.73's 26 tall tire
questions
-is the ls1 based motor dimensionally smaller or bigger than an sbc?
-are the parts forged from the factory?
-how much is a used shortblock/longblock
-where did you buy those motor mount adapters?
-what turbo are you going with?
with my bbc coming out slowly, Im SERIOUSLY thinking about doing an ls1 since I already have the fuel and megasquirt in place.
It would lose about 200lbs, and Im hoping it wont take up anywhere near as much engine bay realestate.
Discussion Starter · #16 ·
questions
the ls1 is about the same size as a small block
the parts are not forged the pistons are Hypereutectic from the factory- most limiting factor of an ls1..
if your going to use boost i would suggest a lq4 6.0l or a lm4 5.3 truck motor the good thing is that the truck motors are more available. i am in the process of trading the ls1 for a 6.0l now..
i would say average price for a motor with harness and accessory is about 1500 plus shipping but there are better deals out there 5.3's can be found a little cheaper but they love boost!
the motor plates were ones that i made.. but there are a template off a set of car shop plates.
and the turbo i will be using is a master power t70.
i would go Ls motor all the way! the stock blocks and cranks have been tested well over 1+++hp!
Yeah, they can hold power for sure. I was reading your thread on ls1tech and it seems like maybe more work than meets the eye. One thing I hate is surprises because it usually involves money that one didn't plan for
Discussion Starter · #18 ·
its very time consuming if you have a large budget and are doing a N/A setup it could be done pretty cheap but starting from noting and building a turbo car takes some money. i try to build every thing i can to save some cash.
my biggest question is still
which pan will bolt up and clear the crossmember without hanging too low. is there a pan like this that can be bought?
also, the truck manifolds - do they bolt upside down and rearwards on the engine without any mods?
Discussion Starter · #20 ·
No And no lol..
i personally have tried the truck manifolds have a set here they will hit the steering box if there one normally installed..
the canton oil pan may clear without hanging too low.. thats why i built my own..
1 - 20 of 138 Posts
