My 66 Canso SD project
39K views 112 replies 27 participants last post by  romancommander
Spent a little more time in the garage today/night. Got the 3/8 fuel line in the stock sending unit( trick: filled the line with sandblast sand and pluged at each end so it wouldn't kink ), will use the old supply line for the return line, just have to silver solder new line in. Also got the computer sorta mounted, cut down the orig truck mount so there is still air space between the fenderwell and computer for cooling. Figured I could use stock acell lincage and think it will work fine, just have to make a mounting bracket to hold throtle cable. Progress so far :)
I see you're using "Bud" tools as well!! They're the best in helping with any project!! :D:D
Nice color Jim. Our Cloner I did in the same color!! Awesome. Yes, very hard to take a true pic of the color!! Flash changes it as does bright sun. Need an outside shot on a bright day, little overcast. Carry on, it looks like its gonna be sweet. Do you have the "all important" trim bits n pieces??
Good Luck. BOGIE
