Hi all,
I am hoping that I can some direction on what is causing the MSD 8360 distributor to not provide consistent spark. I have not been able to trace it down but I have had spark, at the plug, twice and the motor actually turned over and ran once but since then nothing. I put a meter on the positive side of the coil and with the key on it is at 12v but drops to 8v at cranking. The intermittent spark is from an obvious power drain I have not been able to locate.
1) I grounded the distributor wire to engine no spark.
2) I ran a ground from the distributor to the frame and got a spark
3) I routed all of my plug wires and then I had no spark again.
4) I replaced the ignition wire from the coil to the fuse block
5) I tried a relay, nothing
6) I sent the distributor and coil back and got a new one still the same problem.
I am really confused as to what I could be. The coil is a Master Blaster 3 the battery is brand new and fully charged.
I do have a single wire alternator and a mini starter in it
68 Nova 388 400 turbo
