Car had factory a/c and heat but previous owner removed both. I installed the fiberglass a/c delete panel to hook the heater back up. Everything works but need to mount the resistor and relay somewhere.
The relay I can just mount to the outside of the fiberglass heater box or I might solder linger wires to tuck it into the fender below the blower motor.
The resistor is a different story. Looks like I should cut a hole in the heater box and insert it like the factory a/c box but it would be deep enough to almost touch the firewall.
Has anyone else done this or have recommendations?
