I should be enough, the shaft is mainly to ensure proper alignment to eliminate wobbling, the bolts keep it secure.
Mike
Mike - 74 Nova Baltimore, MD
I agree with Mike52. You should be fine installing your clutch fan using the new pulley. Just be sure the bolts are long enough to securely engage the threads in the water pump's mounting hub.
Thank You RifRaf! I'll make sure the bolts are going all the way through the threads... Bill
