1 - 15 of 15 Posts
So, I have my motor/tranny back in. The pass side header will not clear the trans x-member. I purchased new motor mounts from summit
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PIO-A2292&N=700+0&autoview=sku
and slapped them on there. Didn't notice anything different that would indicate they were Left or Right mounts.
The motor does sit a little crooked in the engine bay, kinda leans toward the driver's side by about 1/4".
Are the engine brackets on the side of the block L and R specific?????
· Premium Member
My headers stop short of the cross member too. When I put the flange on the end of the collector (3-2.5" reducer) it's about 1-2 inches away from the cross member and is the same distance from the floor board as the x-member. If I attach my exhaust pipe it will not pass under it.
Looks like I might have inadvertently switched the motor mount brackets that attach to the block. If they are L/R specific, that could be it.
hope that makes sense
Thats the correct frame mount for a 73 as I just removed my factory ones today. I dont think they make a pass and a drivers side.....I believe they are interchangeable. Ill look at my old ones tomorrow to see for sure. Did you just re-use your mounts that bolt to the block?
They are the same for left and right. Are you sure you used the right holes? And do you have 4 bolts in the crossmember? If you only have 2, you might have it too far forward(it could happen). Also make sure both sides are using those little tabs welded off the back of the engine crossmember on the upper bolt holes.Bluesman,yours a aftermarket ,his are stock,that's why they look different.
· Premium Member
I am sure you guys are right about the differences between a '71 and a '73, but I think I am also mixing them up. Doesn't his link take you to the mounts that bolt to the crossmember? I am looking at the ones that bolt to the engine...the "other half" of the mounts. Sorry about that!:rolleyes:
Dave
Discussion Starter · #10 · (Edited)
I did reuse my engine mount brackets. I have 4 bolts for my x-member so it's in the right spot. It lines up with the tranny perfect. I also used the welded tabs for the top rear holes of the frame mounts.
I pulled both sides off yesterday and compared what I had on L and R.....
The passenger side frame mount is 1/4" taller than the one that I put on the driver's side. Both are new from summit and had identical part numbers.
The engine brackets that bolt to the side of the block were different too. The one I had on the passenger side was 1/4" to 3/8" of an inch taller than the driver side. These were the mounts on the car when I bought them but I never checked them for differences before I put the motor back in as I thought they are for either side.
I ended up switching only the engine brackets and leaving the slightly taller frame mount on the passenger side. I compared them side by side in that configuration and they appeared to be the same height (assembled). SO I went with it.
I installed them that way and now the motor sits almost level, I'd say within a 1/16" to 1/8" with a slight lean toward the drivers side.
Now I have another question..... Should the center bolt of the balancer/crank line up with the center of the engine bay? (ie crossmember, center of front clip)
My motor is shifter towards the passenger side by about a 1/2" to maybe 3/4".
Thanks for all the replys.
· Premium Member
Not necessarily. These old cars were not put together by brain surgeons. Your drive train may be off-center either at the front or at the rear. Mine was 3/4" to the passenger side at the rear when I measured. I haven't really checked the front, but who's to say the cross member is exactly centered! Hey! It goes down the road...right!!??:cool: That's what U-joints are for, isn't it!!:turn::turn:
Dave
Discussion Starter · #12 ·
Dave
Well, I just went and bought new motor mounts (frame) from AZ. They are identical in every way. I took a closer look at the mounts I got from Summit and the taller one is actually slightly different besides being taller. I'm going with two from AZ, and I'm putting the bigger engine bracket back on the passenger side. That one has a #3998658 on it. I can only find a 72 on the second engine bracket...... i'm putting that one back on the driver side. I believe that the motor will get closer to center as I never noticed the motor that far off of center when I had the mounts on there like that before.
Originally, I had the taller engine bracket with the taller frame mount on the passenger side which is what made the engine lean toward the driver side.
I'll let you know how it turns out. It may be that the engine bracket with #72 on it is from another application because I have found that the #3998658 is the old part number for the passenger side. Correct me if I'm wrong on that one.
Thanks again.
Discussion Starter · #13 ·
Well, the scenario I mentioned above worked!!! The engine brackets are R/L specific. With the AZ frame mounts (identical in height/size) and the taller engine bracket on the passenger side............. The motor is now level and centered in the engine bay.
What a freaking PITA.... One slightly different frame mount from summit gave me such a problem. Hope this info helps others.:D:D:D:D:D
1 - 15 of 15 Posts
