Anybody ever had a torque converter not want to let go of the flexplate?? Got all the bolt out but it just won't let go. Any suggestions.
You did remove the 3 bolts holding the converter to the flexplate, if so I would use a pry bar and pop it loose. I have pulled more engines than I care to count and have not ran into that problem. If you are positive all the bolts are out on converter and the tranny bellhousing it should seperate.
The snout on the torque converter was rust welded inside the crank. After enough force they were finally divorced. Floor pan replacements are next on the list.:D
