Hello all. I am soon to be in the market for a mini-tub on my '72 Nova. What I don't have is a welder (and for that, any experience welding), cutting tools, or really anything to do any body panel work. This is where you help.
1) What welder should I be looking for to appropriately and correctly mini-tub my '72? I keep an eye regularly on craigslist, so if I can come across something there, what should I look for? I obviously won't just buy a welder and go, I will get some practice beforehand on scrap metal. My only limitation is the 110 socket in my garage (currently in an apartment), but I believe I can still find something powerful enough to weld sheetmetal, and possibly some suspension stuff (coil-over mounts, etc.)
2) What cutting/grinding tools should I look for? Angle grinder, die grinder? Should I be looking at an air compressor for this as well, or would basic electric tools get the job done?
3) Anything else you can think of that I will need to know to get this done. (shock mounts, coil-over?) Current rear-suspension is leaf-spring. What would it take to convert over to a coil-over setup?
Current rearend is an 8.5 big 10 bolt with stock 28-spline axles. I know the axle tubes will have to be shortened, but by how much? Does Moser, Strange or somebody sell axles (custom) the right size?
Thanks for any help.
