1 - 13 of 13 Posts
I'm wanting to mini tubb my 66 ht this fall and have a bunch of questions. Im posting this to see if anyone could help me out.
1)i really dont have any idea what the best rear suspension set-up would be. I have a 550 hp motor running to a brand new dana 60 rear end from strange. I know the rear end would have to be shortened, but i dont know what length the rear end should be..and
2) dont know what rear suspension to go with(tci, alstons, etc)
i want to be able to put a nice 10-12inch wide tire on the rear and was hoping someone would be able to show me photos of their completed projects and any help would be beneficial.
Also, i can not do the work and was hoping someone knew a good shop near northwest indiana area, chicago area, indianapolis area. If anyone has a rough price of what it would cost to completely get it minitubbed i would appreciate it.
chris
Banned
mini tub
chris
down here in TX its 900.00 to mini tub a 66 nova
My suggestion, if and when you do find a competent shop, is to have them spell out exactly what they will be doing for the price. Widening the tubs, re-sectioning the package tray supports to correctly fit back in, relocating the spring tabs, and/or fabricating new front and rear spring mounts. Widening the tubs is but a small part of the whole package. Sometimes, its not realized what needs to be performed to get the widest tire possible up in there. I always tell someone I do this for, that my estimates are rough, and at any time they are welcome to check where I'm at relevent to the project. Its important to know "how" a shop is performing the work you want done. Good luck!!
For 12" wide rubber you might not even get away with just a mini tub - frame has to be narrowed.
You are looking at some real amount of work!
Regards from overseas
Boris
285's are about all you can comfortably shove up in there without sectioning/moving the rear frame rails.....but I wouldn't.
A well done mini-tub looks factory and you get to keep the rear seat.
Boris
I have like 14 1/2" from wheel lip to frame rail on mine after mini tub. I notched rails as you can see in picture. I also kept the curve of the front part of the inner housing tight against the rail a lot longer than the factory, which freed up more space without that sharper turn inwards. Replacement strip was like "3 1/2" " as opposed to the "2 plus " in the back .I stuck a 285 tire in there and have tons of room left. Granted axle length and backspace can affect final outcome. I am gonna borrow a 315 from local tire store and see how that goes.
[/URL][/IMG]
[/URL][/IMG]
I have several pics on my link below of the steps I went thru on mine. Maybe it can give you ideas or help
Banned
mini tubs
Trust me, Dales right. There is a ton of work involved to do all the things that go along with the mini tub. I bet it's more likely $2000 to have it all done. Maybe more. I did all of mine myself and it took many weekends:yes:
Ron
trust me if its your first go around it can take a long time, no problem for the steppers.
1 - 13 of 13 Posts
