Hi,
I'm really new here and only owned my 1965 Nova for 10 days now.
Long Story......
The car appeared to need an ignition switch. The key turn loosey-goosey and when I turn the key to "start" the car cranks but it didn't start until I turn it back to "on". It took me many tries and the starter gear and flywheel were gonna take a beating.
Immediaately started looking for a new switch. Couldn't find the right one. Everywhere I tried said the part was a one year only and discontinued. I settled for a 62-64 part and against my desire not to jerry-rig things, it had to clip off the harness connector and use insulated push-on connectors. Tight working up there. I'm not as flexible as I once was and the car has an aftermarket stereo and a triple gauge set in the way. After I was done, the car started easier but somethings not right. Well, though the car starts much better, it still doesn't actually start until the key is turned back to "on".
I found schematics on this site. Thankyou Steve's Nova members.
The Question.....
I'm not an electrical wizard so can some verify something for me.
The schematic shows the "on" (ign 1, BLK/PNK) in the dash harness, pass through a multi connector to the firewall harness, changes color to WHT-ORG-PUR resistor wire to a post on the starter solenoid. (but this isn't the sol lead, that (purple)comes from the switch to another connection here). Another BLK/PUR is connected to the same post as the WHT-ORG-PUR and that goes to the plus of the ignition coil. It appears, power to the coil comes from the starter (relay) while cranking. Something here must be missing or broken, assuming the starter relay is good. I'm guessing it is because the motor and transmission has less than 3 thousand miles on it.
Thanks in advance if you can verify or correct my schematic reading ability.
KDee
Long Story......
The Question.....
KDee
