I only did a small part of the bottom of the body shell, I am using Black Magnum media. I did a floor pan and then started on a brace piece and it took it down to bare metal (silver) then it started to take a thin layer of something else off with bare metal under that also.
What is the coating that looked like bare metal???
I was thinking it might be a galvanized coating or something like that.
If so do I leave it on or take it off? I will be spraying a primer down before
I put on the Chassis Black.
I am allergic to EPOXY so is there a primer I could use before the Chassis black that is not a etch primer or and Epoxy primer?
