What would be some good mechanical rollers to use on my 421 street engine build?
Are there some that are better suited for street driving?
Don
Don
Yes, lots of differences for different lifters. Some lifters (the cut-away style) can't use rev-kits. Just check with the manufacturer of the lifters you get.:yes:Good information on roller lifters. Thanks to all who responded.
Looks like the rev kit is the way to go.
Is there any difference between rev kits, hydraulic roller vs solid roller? Or are the springs the same for both?
Thanks Al for the photo.....
Don
They do make rev kits for the vertical bar lifters.Yes, lots of differences for different lifters. Some lifters (the cut-away style) can't use rev-kits. Just check with the manufacturer of the lifters you get.:yes:
What type of seat and open pressure do your valve springs have?What would be some good mechanical rollers to use on my 421 street engine build?
Don
Al, I knew the vertical bar lifters could use a typical rev kit. Some (because of the style of capturing) require a little different seat than others.They do make rev kits for the vertical bar lifters.
The seat cup is a tapered tube that fits on the out side of the push-rod cup.
Kinda funky looking.
http://www.dougherbert.com/revkit-p-10167.html
http://www.dougherbert.com/revkit-p-10168.html
Don,cstraub
I am just doing some "homework"
I am getting ready to order the heads. Don't have them yet.
AFR-1054 210 Eliminator race 64 chamber.
I need to find out the spring pressure requirements for this Lunati cam (60142)
then I can place the order for the heads.
Don
FYI:With core supply the way it is I grind all SBC on a P55 core. This is the old race core used for many years and it is much more durable.
Also AFR have very good I/E ratio, I don't know what this cam looks like but these heads respond very well to tight duration splits. . .2 to 4 degrees..
EDM lifters are the only way to go if you are going solid flat tappet.
Why not a hydaulic roller since this is a street car? That makes it quite simple and you don't have to worry about the other issues. The little bit of performance gain is not going to make any difference in a street car.What would be some good mechanical rollers to use on my 421 street engine build?
Don
Would respond VERY well to more rocker ratio on the intake.
