1 - 3 of 3 Posts
will a 67 dual master bolt up and work in my 65? non power brakes.
Yes. Obviously, you will need to modify your lines Is it still drum/drum? If so you would be fine. The 67 also used a distribution block that you can use also (if you have it). If you are going with a disc/drum set up I would recommend a combination valve as the residual pressures are different between disc & drum.
I did this when I still had 4 wheel drums on my '65. I used the '67 drum brake distribution block and bracket. It was a direct bolt-in (except for all the metal brake lines).
1 - 3 of 3 Posts
