1 - 2 of 2 Posts
I am in the process of changing over to front disc brakes on my 66. I bought a 68 nova manual master cylinder for front disc brakes at the local Napa store. Do I need to run a proportioning valve with this master cylinder? If so should I run a adjustable one or can I pull one off a donor car?
YOU NEED PROP.VALVE...ONE FOR A 72 Chevy pick-up disc brake front end would be perfect can also use an adjustable
1 - 2 of 2 Posts
