Is this what came off of your car or is this what you are putting on? Are you running dics brakes or drums? It does make a difference.
Call Lone Star Calipers, very knowledgeable and helpful.
You can get it rebuilt. Make sure you check cylinder depth to match and if your lid starts leaking after replacement, try bending the wire a bit to hold the lid on tighter.
What is the reservoir configuration? 2 small? 1 large/1 small? 2 large?
What pushrod is it set up for? Deep cup? Shallow cup?
Are you looking for an original numbers correct replacement? Or just one that works as a replacement?
