What is the proper master cylinder piston size to use for a manual brake system using disc on front with rear drum brakes? This is for a '67 with a front disc brake conversion.
I used a 68-74? Vette manual master on my 66 for awhile. 1” bore and cheap but if you use it you would new a 10# residual pressure valve for the rear line because vettes were disc/disc
Wilwood suggested to me both 7/8 and 15/16 for manual brakes
I like the feel of the 7/8 better on the street. A little softer pedal
I put the 15/16 on the twin turbo 72. I believe I was told it would hold better on a foot brake but I dont remember my physics enough to tell you further lol
I believe wilwood is worth the investment
