To sum up what could be a four paragraph explanation as to why I'm writing this, I'll give you the summed up version: I have a bunch of junk that I want to bolt together to get my Nova driving instead of sitting.
Long version:
I have a complete, running, relatively low-mile 400 small block at my disposal (block casting 3951511, out of an early 70's Impala) with some weirdness added in. It was plucked from a running and driving plow truck that my father scrapped; he installed the engine some 20+ years ago and daily drove the truck for 5+ years in what he thought was box-stock form. I, myself, drove the truck with this engine in it, even though it always ran half-ass.
The plan is (or, was) to take this engine, toss a little cam in it, and then plop it between the fenders of my Nova for the sake of being able to drive it around town and have some low-buck fun. I don't care that it'll be a wheezing, low-revving turd; I just want to be able to cruise it around with my family and have fun while I build the 350 the "right way" while the missus is in school (read: I have a lunch money budget, so the wild drag motor is going on a stand until I can afford good heads to make it live on pump gas). This past weekend, I decided to do some forensics on the 400 to have some data points... to which the weirdness began.
As previously stated, it's a 3951511 block, crank, rods, and pistons. Or, so it appears. The heads, though... the heads aren't the same. One is a factory 997 casting (76cc boat anchor), and the driver's side... is a 601 casting (H.0. 53cc off of a 305). I have absolutely no idea when, or where, this occurred, but like I said previously... the motor ran and putted a 3/4 ton truck down the road for years. So, at least the shortblock is usable, I hope.
Now, the proposed solution.
I have a pair of complete, refurb'd 291 heads with 2.02/1.60 valves in them ready to go (were gone through years ago and sat on a shelf). Yes, I know they suck compared to modern heads. Yes, I know the intake ports are small for the bigger-inch 400. Yes, I know I need to drill steam holes. But, they're what I have for free, and they're usable. My question is, will they work well enough to add a little life into this engine to go down the road?
I planned on robbing parts off of the 350 to get it completed (750cfm 4160, Pertronix distributor with VA, headers, Weiand single plane, and the accessories). The 350 in the car now has wild compression (read: 12.25:1 static / 9.5 dynamic) and cut heads (62cc 461's), and it genuinely needs something like a pair of 72cc aluminum heads to knock the squeeze down.
I'm not after a fire-breathing engine, I genuinely just want to put something together using nothing more than a gasket set, a dual plane intake, and maybe a small cam kit. All off the above parts are available to me, completely 100% free.
Am I ****ing crazy?
Photos for your attention.
The car.
The existing 350.
The questionable 400.
Head casting on the driver's side.
Head casting on the passenger's side.
The spare 291 heads.
Long version:
Am I ****ing crazy?
The car.
The existing 350.
