Paterns shown here are for a 64 ChevyII
Here are some tips on how I make my poster board paterns.
Most of my paterns have been made before the rusted metal is cut from the car.
Some paterns can be reversed and used on both side of the car.
May help to label them (top, front, Ect.)
Can be made in more than one piece and taped together.
Here I have cut a piece to fit in the side of the cowl for making a patern for the vent opening.
I am using my fingers to rub on the poster board and leave the outline of the opening. If you have a little dirt on them it can only help the ouline show up.
Now I am traceing the outline to make it easier to see. This is the side that was faceing the opening. Sometimes there is more dirt on the car than your fingers and this side shows up better.
Here I have cut the hole out to small to be sure how it lines up before I cut it out to the line I have drawn on it.
Vent opening partern ready to use.
Here you can see that the posterboard can be folder around corners if need be. I am making a patern for the upper panel that forms the front of the cowl side.
Using fingers to outline the outer edge of the patern.
The very top corner of the panel was still there at the brake in the metal,I was able to mark a starting point. I also eye balled the other side to help find a lower referance point for the top edge.
Here I have outlined the main part or the panel useing the creases I made with my fingers.
The first part of the outer lip was strait for 5" as far as I could tell. Here I Am marking the first part of the lip at 1" wide.
Next I added the outer edge of the lip at 3/4" wide. I made the lower 5 " of the lip as part of the panel.
Main part of partern after cutting out. This is a good time to see how the patern fits the part and tim if needed.
The upper part of the outer lip is curved and I made a patern for the outter lip the the rubber seal was stapled onto.
Here are the paterns when done. The space between the main panel and the outer lip will be filled with a 1" strip that will be tack welded and bent as I go to meet the curve of the main Panel. Then the outer lip will be tacked on.
Stitch weld it all and plan on girnding. Keep it cool.
Other paterns I have made in the past.
End of frame at the rear leaf spring mount.
Trunk drop panel. Made a patern for the drivers side were the gas tank filler pipe is. The other piece is a add on to make the patern work on the Passernger side also.
