I have a 2000 Ls1 and I have modified the stock harness using the LSx Engine Harness..... The Mystery Unraveled (Tutorial).
I got the motor running and it tripped the, MAF sensor circuit low input code. I tested the MAF sensor and it does not have 12 volts at the pink and blk wire at sensor .
My question is is there any sensor that share's the the power with this wire ? I have looked at the harness tutorial and I don't see MAF sensor mentioned as a separate wire. If I erase the code take and jump 12 volts to the sensor it will not trigger the code.
Thank's,
Bruce
Thank's,
Bruce
