yes>>>>>>>>>>>>>>>>>>>>i'll have to take the side cover off and take a look at the gear angle to be sure.
Not true. Any could have had the drain plug drilled. You cannot tell by the case if it is an M22.Per Chevy by the Numbers
All 1963-69 Muncies maincases, only the M22, was drilled for a drain plug.
All 1970 and later Muncies have the 32 spline output and 26 spline input. All 69 and ealier have a 10 spline input and 27 spline outputif i remember right the M22 also uses the same yoke as a TH400...
Yup. No rings on the input shaft is a good clue, but early M-20s also had no rings. If it has no rings and a 26 spline input, it could be an M-22 if it doesn't have an aftermarket input shaft. You really have to open the side cover to know for sure. In first gear, if the output turns once for each 2.5 turns on the input, it is definitely an M-20 or possibly an Autogear wide ratio M-22.Pull the cover, thats the way I checked mine before I bought it.
I'm not a fan of the M21/M22 either. When I rebuilt my M-21, I made it an M-20. There are a total of two internal parts that differentiate an M-20 from an M-21 and a total of 5 internal parts that differentiate an M-22 from and M-20 or M-21. My case has a drain plug too.I have to laugh about this. Back in the day (when we were driving these cars every day) I couldn't TELL you how many Muncie trans we blew, and mixed and matched parts to build others. It never mattered one iota what the case said, only that we got one back together to drive that night. You used to be able to buy them for 50.00-100.00$ all day long. I personally had about fifteen whole trannys and piles of parts (from blown ones) at any one time. They never lasted very long. We always used the wide ratio ones (running lower gears they were better) and sold off the close ratio ones. In all those years, I never ran across an M22 (and I must of had over 100 of 'em). They seem to be coming out of the woodwork now, but you can also buy replacement parts where years back they were very scarce. Bottom line I'd NEVER trust what a case spec'ed out to be, chances someone like me blew it a few times over and mixed parts because driving was what mattered.....
The Autogear wide ratio M22 has pretty good gear spacing. The M20 is really nice if you are trying to get to 85 MPH quickly, but the 3 -4 gap is large.Back in the early 2000s I built a 22 out of brand-new parts (in a old original 22 case). Haven't ran it yet but now that they make wide ratio M22 gears and the fact that I bought a Supercase with the steel gurdle makes me think I'm going to sell off the 22 close and build a 22 wide.....
i like the M20 because of it ratios..... what are the ratio's autogear is offering for its M22 wide ratio?The Autogear wide ratio M22 has pretty good gear spacing. The M20 is really nice if you are trying to get to 85 MPH quickly, but the 3 -4 gap is large.
1st 2.56i like the M20 because of it ratios..... what are the ratio's autogear is offering for its M22 wide ratio?
